Zum Hauptinhalt wechseln
Released in 2019, the XPS 13 7390 is a 13-inch traditional laptop with a 10th-generation Intel Core processor inside. Don't confuse this laptop with the XPS 13 7390 2-in-1, which is similar but has a 360 degree foldable display.
Battery replacement for the XPS 7390 model
I can see you have the Dell XPS 13 9343/9350 Laptop Battery replacement available, will this work with the XPS 13 7390 model? I'm having a !&&* of a time finding a reputable seller and some guidance would be greatly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Ifixit gives a 1 year warranty on the battery, which is better than most.
If it doesn't work then at least you will get a refund or a new battery
Scroll down to description and warranty. Also see Shipping restrictions on the page
Replace a 52 Watt Hour (Wh) battery compatible with select models of Dell XPS 13 laptops. Bild
Produkt
Dell XPS 13 Battery - DXGH8
$98.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kingsley Gittins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 455
