Zum Hauptinhalt wechseln
Reparatur- und Demontageinformationen für die Sony WH-1000XM2 kabellosen, geräuschunterdrückenden Over-Ear Kopfhörer.
Damage to Charging Port Sony WH-1000XM2
I have accidentally push the charger into the charge port in the wrong direction and have bent two of the pins inside the port. I need to replace the charging port but I am struggling to find parts or a guide. Any recommendations on where I can find a replacement port for Sony Wh1000xm2?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
if you can get it opened and post a photo of the port it would help as not all ports are specific to an item
von
hi Daniel I have managed to get it open, here is the image: https://imgur.com/2tf0lNi
von
Einen Kommentar hinzufügen
1 Antwort
HI @lmalfunctionl
I made a guide on a similar model
SONY WH-CH700N Bluetooth-Kopfhörer USB-Ladeanschluss ersetzen
I think the micro USB part is similar in yours:
https://www.ebay.co.uk/itm/142512274587
Hope it helps!
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Hi Honakrisi, thanks for the guide. Here is a link of the part I am looking for.: https://imgur.com/2tf0lNi
Would you happen to know if I am able to source this part with the board or if it is better to solder the port on?
von
I think you would struggle to find the charging board assembly. I would just desolder the port and put a new one on. Much more cost effective as well.
von
Hi @lmalfunctionl
If your in Australia, grabbing a port from jay car works. I've done this before and it still works wonders
If not, disregard all of that and just find a cheap but quality port and a soldering kit (If you don't already have one)
von
Antwort hinzufügen
Kajol wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 29
Insgesamt: 1,732
