Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 11" MacBook Air enthält Intel Core i5 und i7 Prozessoren der 5. Generation, was die Leistung und die Akkulaufzeit etwas verbessert.
iFixit Battery received has a protection film all over it.
Hi ,
I have received a new battery from iFixit today for my macbook air early 2015.Upon opening the box , i have noticed that there is a protection film ALL OVER the battery and not like in the guide description NOTE:
Note: If there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
This is not only over the battery cells but all over the battery...
Should I remove it for installation or keep it?
Many thanks in advance.
Picture attached for reference.
Update (08/16/2022)
I am just thinking that the plastic might affect the battery , as this is my second batter from iFixit and the first one, did not have anything like this...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hey all!
I got some information from iFixit EU side this morning:
Thank you for your message and the purchase from our Store.
The plastic film seen on your picture is supposed to be removed.
Should you have any other questions, please feel free to ask.
Kind regards,
Leon (iFixit EU Team)
War diese Antwort hilfreich?
Bewertung 3
Hilfreichste Antwort
@xdrqgol leave it on and install your battery as shown in the guide
Bewertung 3
8 Kommentare:
First time you said: you will have to remove that to install your battery. If you do not then the glue strips would not work. :D I am skeptical ...
von
Yes that is because I just did a Macbook Pro and it had the glue strips covered and a protective cover over that. A case of mistaken identity not realizing yours was a MBA.
von
I am just thinking that the plastic might affect the battery , as this is my second battery from iFixit and the first one, did not have anything like this...But also the holes matching in the protective film , which makes it available for you to install it with it ON, is also something that makes me think..
So I would need to know what to do from someone who had a similar battery from iFixit ..
von
I understand but if it would just be a removable plastic it would not have the holes in it and your battery is secured by screws not glue strips. Who knows why the other one did not have it but I would go ahead and follow the guide
von
@oldturkey03 yes that makes me think about it. thanks
von
3 weitere Kommentare anzeigen
I have an answer @xdrqgol! With this particular model of battery it's up to you. You can leave it in and it won't melt or you can remove it.
Bewertung 1
Antwort hinzufügen
Rasmunson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 43
Insgesamt: 1,764
