Zum Hauptinhalt wechseln
Das ist die 8. Generation des iPads, erschienen am 18. September 2020, erhältlich als 32 oder 128 GB Modell. Die Modellnummer ist A2270.
Pinout of Home Button Connector? iPad 8 Wifi, torn pads
I have a iPad 8 and some monster pulled a few pads off trying to replace home button zif connector. I started scraping to see if I can follow the traces. They are not clearly seen through the mask like I see some show.
Didn't want to start tearing all the mask off, and figure someone has seen this. Do we know where these traces go to ? Does it even use all the traces? iPad 8 seems to be the only ipad I don't have info on. Here is a pic of what I have under the microscope.
Thanks in advance !
Update (08/20/2022)
Oh my bad, it's a A2270
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Oddly enough, the pads that lifted are not used. The half pads I was able to use and still connected. I believe I'm good, i'll assembly and test. Purchased ZXW to confirm pin location to componets.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi
If you get a multi metre and put it in continuity try this
Put one probe on ground and the other on the bit that you scraped the mask off and see if there is continuity to ground
The reason why I am ask for you to do this is because it looks like a ground pad because of its size,obviously it’s quite hard to say but I don’t see traces going under a connector very often
I would have a look for a schematic and Board view so you can see where the actually go
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Hi does anyone have the schematic for the iPad 8 for the above area as I lost what looks like a micro resistor
von
The area is near the FPC connector on iPad 8 WiFi A2270 I lost a resistor but cannot see the value as they don’t seem to be written on
von
Antwort hinzufügen
Eric wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 708
