Zum Hauptinhalt wechseln
iMac Intel 27" EMC 2309 (Ende 2009, Core 2 Duo 3.06 oder 3.33 GHz) ID iMac10,1, EMC 2374 (Ende 2009, Core i5 2.66 GHz oder Core i7 2.8 GHz) ID iMac11,1
467 Fragen Alle anzeigen
Dead Display, Everything Else Working
This is on a late 2009 iMac 27" A1312.
Was replacing the ODD. When I put it back together there is no display at all. It chimes and boots, I got into it via Screen Sharing with my laptop. I am currently backing it up.
Checked all cables and temp sensors, they appear fine though the Vsync cable is looking a little worn.
My main question, since the display is completely dark, no faint image, no lED bars, nothing at all on screen, does it sound like a power supply problem, or if the connector on the logic board right over the video card is boo booed, and not letting any video signal in to the monitor will it prevent startup of the lcd itself.
I don't know the order of steps for power up of the LCD. Also does the front plastic have any sensors on it that might prevent the kid from powering up?
Thanks,
George Harrison III
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Thanks Guys, I figured it all out thanks to your information. What happened is while I was removing the main video cable it broke a pin on the logic board portion. I am using the second display now until I have time to solder a new bracket on there.
Now my second problem, how do I switch my bootcamp over to the mini display port? I cannot boot into my windows and get to my work stuff.
Thanks!
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Depending on the iMac model, it has either three or four built-in diagnostic LEDs on the main logic board that can help you to troubleshoot the computer. The LEDs are located either to the right of the battery or to the right of the RAM and may be covered with black tape.
LED #1
Indicates that the trickle voltage from the power supply has been detected by the main logic board. This LED will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the power supply is faulty.
LED #2
Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED #3
Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement. Note: this LED is not used on systems with the integrated graphics
LED #4
Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
_
I noticed you already checked it with an external display and found a picture. Please tell us what LEDs are lit. I think I left you a good enough explanation of what they indicate.
War diese Antwort hilfreich?
Bewertung 7
2 Kommentare:
Similar problem. I have a 2011 imac with a faulty screen that only lights up occasionally. The internal screen was having a problem where the lower left half of the screen was darker before it devolved to booting to a black screen. It had been only booting to black for a while but after leaving it on black for a day I rebooted and it lit up. I plugged in an external monitor, set it to mirror and tried rebooting. Black screen & no external video. What does it mean that the external monitor fails to light up when the internal screen fails to light up? Video board? Does the prior dimness of the screen coupled with lack of external monitor support suggest that both the video card and the panel are bad?
von
The light number 4 isnt light it is possible from having no temp sensor
von
To help isolate the problem hook it up to an external monitor. Check the diagnostic lights to the right of the RAM and let us know your results.
Bewertung 5
2 Kommentare:
OK will do, Going to have to run to Bestbuy and pick up a display adapter. And thanks for the info on the lights, I didn't know they existed! As soon as I get back from Bestbuy I will post again.
von
I went ahead and looked at the lights beside the memory. If I am facing the computer the only lights I see are to the left of the ram. Looks like two steady green lights. There is nothing to the right of the ram lit up.
von
Antwort hinzufügen
GEORGE HARRISON wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 26,509
