If you have security questions set during under your Google account security, then you will be able to unlock your device by answering these questions.
Step 1: After multiple wrong attempts, you will get “Forgot Pattern” or “Forgot PIN/Password” option.
Step 2: Tap on it, and then select “Answer Questions” option.
Step 3: You will be presented with your Google security questions which you have added in your account. Answer them accordingly.
Step 4: If you answer the security questions correctly, you Samsung Galaxy Tab A7 will unlock.
Step 5: After successful unlock, you will be asked to create new PIN, Password or Pattern Lock for your Samsung Galaxy Tab A7.
To unlock Samsung Galaxy Tab A7 using your Gmail account, follow below-mentioned steps:
Step 2: Login with your Google (Gmail) account by entering its details such as username/password.
Step 3: Once you are logged in successfully, your smartphone will be unlocked.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
