Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage- und Fehlerdiagnoseinformationen für das Apple iPad der 5. Generation mit Wi-Fi, erhältlich mit 32 oder 128 GB Speicher. Erschienen im März 2017. Identifizierbar durch die Modellnummer A1822. Ausgestattet mit einem 9,7" Retina Display und einem 64-Bit-A9-Prozessor.
Can you remove the little circle around the home button?
picture So im repairing my iPad 5 rn and i saw this little plastic ring around my homebutton, i decided to remove it as its just a piece of rubber and plastic, but maybe it served a purpose? lol. Does anyone know if this is bad or can i continue?
Update (08/30/2022)
This, teh left (rubber was first atteched to the back of the plastic one and surrounded the homebutton together.)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Can you add a picture of the object?
von
@Traxced
We can’t see the images as they are a comment
You need to add them to the original question
You need to edit the question then add them. :-)
von
@hellomacos yep i noticed lol, i did it now!
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If you mean the gasket? Then you will likely need this. It helps to mount the button to the display and stabilize it. It also provides some very minimal protection against liquid entry.
Replace the adhesive gasket that holds the home button face onto the back of the front panel glass compatible with an iPad 5, iPad 6, iPad Air 2, or iPad mini 4. Bild
Produkt
iPad 5/6/Air 2/mini 4 Home Button Gasket
$1.99
War diese Antwort hilfreich?
Bewertung 5
Hi
From what the photos show that is a gasket
This isn’t necessarily needed but it helps keep dirt out
You could use some light adhesive on it or order a new one
But as I said your iPad should work without it but it’s recommended that it’s there
Hopefully this helps
Any questions please ask
Bewertung 2
Antwort hinzufügen
Traxced wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 40
Insgesamt: 559
