Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
150 Fragen Alle anzeigen
iPad 6 battery drain while standby
I’ve received and iPad 6 to repair. Turns out not only the glass was broken but the battery was dead and the LCD is cracked.
I’ve replaced the glass and the battery. The iPad turns on and works great. Except for the cracked LCD which I still need to replace.
Before investing in a new LCD I noticed that the battery would drain quite fast.
I’m losing about 2% an hour while standby. Playing a YouTube video will drain the battery from 100% to 0% in about 3 hours.
Notes and things I’ve tried:
  • Restore the iPad (I’ve not yet done a DFU restore)
  • I’m not signed in to iCloud, iPad is factory reset. There are no apps running, no Find my process.
  • Charge to 100%, run it down to 0, charge to 100% and leave it for 4 hours.
  • When at 100% and connected to Coconut Battery it says 96% charged. When doing a force restart (home + power) it reboots and jumps from 100% to 96% and goes back to charging for a couple of minutes. Doing this a couple of times will end up with 98% in Coconut Battery and 100% on the iPad.
  • Update to iOS 15.6.1
  • The iPad get ‘warm’ on the rear when in use. Right around the motherboard battery connector is my guess.
Could the battery be bad or could there be something else wrong with this iPad?
Could the cracked LCD cause the drain?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The battery would be the quickest and easiest part to check by replacing. If that does not resolve, the iPad may have a bad Tristar IC or a short on the board which will require micro soldering to repair. The cracked LCD should not be the cause of the issue. If the device has a bend in the frame this is most likely the cause of the board issue if one is present.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Thanks for the response Robert. No bend in the frame as far as I can tell. I don’t have the tools to check the Tristar IC. Wouldn’t issues with the Tristar IC be more ‘visible’? Like unable to charge etc? I could buy another battery but the costs are adding up sadly. Not sure if that’s worth it.
von
An update: I've bought a new battery to make sure that's not the problem. Turns out it wasn't the battery. This new battery also drains just as fast. So sadly it must be something else that I'm probably not be able to fix.
von
Hi Rick, sorry just now seeing these comments. If the battery did not resolve the issue, there is most likely damage on the logic board causing the problem.
von
Antwort hinzufügen
Rick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 109
