Zum Hauptinhalt wechseln
Lenovo Business Laptop, welcher April 2011 veröffentlicht wurde. Das X220 ersetzt das Thinkpad X201. Wesentliche Verbesserungen umfassen: Verfügbarkeit eines 1366x768 IPS-Displays, Intel Core CPUs der 2. Generation, ein neuer Trackpoint, neue Ultrabase, SATAIII. Nachfolger des X220 ist das X230.
Cant connect to wifi
My laptop cannot connect to wireless networks why? and help if it can be fixed
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi @otakunoweeb,
Does it detect WiFi networks but won't connect to them or doesn't it detect any WiFi networks at all.
What OS is installed in the laptop, Win 7, Win 8.1, Win 10?
Have you run the network troubleshooter and checked if that fixed it?
What have you tried?
von
It does not detect at all and os installed is windows 10
Yes i have run the network troubleshooter and it hasnt helped fix it
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @otakunoweeb
Check the status of the WLAN adapter in Device Manager - Network Adapters - click on the > symbol to expand the list - right click on the Intel WLAN entry - Properties - General tab - Device status box. Does it say "This device is working properly"?
To get to Device manager in Win 10, press the Win key + x key (both together) and click on the Device manager link.
If there is no WLAN entry in Device Manager, check in BIOS to make sure that the WLAN has been enabled.
If there is a WLAN entry in Device Manager is there a red cross or yellow exclamation mark next to the entry?
if there is a red cross, right click on WLAN entry - Enable and check if it works. Sometimes youy may have to restart the laptop after this for it to work.
if there is a yellow exclamation mark, right click onthe WLAN entry - update drivers. You need to be online (Ethernet?) to do this or you can download the Wireless LAN drivers using another PC etc and then install them and then check.
If still no good then it may be a faulty WLAN card.
Use the manual I linked to your other question (a response on that would be appreciated if you got it working) to see how to change the WIFi card in the laptop
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
sidney wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 791
