Zum Hauptinhalt wechseln
Repair guides and support for Gigabyte laptops produced since May 2003.
27 Fragen Alle anzeigen
What Bios do I use for running linux on a GIGABYTE P17FV7
I am getting errors reported by Linux dmesg concerning "ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)" If I google the error it recommends tat I update the bios but does not give a bios version to update to. Which bios do I use for Linux and what version should I use to get over the error?
Dave,
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There seems to be an incompatibility between the motherboard's BIOS/UEFI ACPI implementation and ACPI code embedded in newer GNU/Linux kernels. Redhat's online help center did in fact suggest to update the system's BIOS in case of ACPI error messages appearing at boot, but honestly I haven't found any info on whether Gigabyte was able to fix the problem. Anyway, the latest bios version from the vendor dates back to 2018, and it's v.1.05.03RGI5.
On bugzilla, a user recently reported he found a fix for his error "ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326) [...]": supposedly, just disabling the sleep states in the BIOS did the trick (procedure changes depending on your bios layout, however generally under "power management" check ACPI_standby_state or suspend type is on S5/OFF)
Also, booting with uefi ENABLED and secure boot DISABLED was thought to be a possible solution.
Hope this helps, if any of these solutions worked for you please share it, your feedback will be useful for others with the same problem
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
David King wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 86
