Dyson 360 Eye goes in circles
the issue is that one of the tracks is loose. would love to see a proper tear down of this vacuum to see how to replace tank tracks as i have a replacement. just stuck on how to remove old set without breaking the vac.
Ist dies eine gute Frage?
1 Kommentar
This is a common problem. Drive wheel slips on the central shaft. I have successfully repaired mine by drilling though the drive wheel (after taking the track off), through the central shaft and through the other side of the wheel. Then glue a steel pin all the way through. I actually used the same drill bit and cut it off - using it as the pin. The wheel now spins. I completed a youtube video on it. https://www.youtube.com/watch?v=2X2sU_Do...
von Derek Scott
