Zum Hauptinhalt wechseln
Ein Tablet mit Google als Marke mit einem 7" Bildschirm. Man braucht nur Hebelwerkzeug und Schraubendreher zum Reparieren. Modellnummer: ME370T.
What is restarting the bootloader done for, in Fast boot mode?
It powers on but doesn't get beyond the power on loading screen. I get it powered off then hold power and both volumes until the screen shows a green bot lying down with the stomach door open. At the bottom left of the screen I see
product name - grouper
variant - grouper
HW version - ER5
bootloader version - 4.23
baseband version - n/a
Serial # - 015d4906bb381410
signing - not defined yet
LOCK STATE - LOCKED
At the upper right corner I see START and arrows up and down. I push the volume down button to scroll through the options of RESTART BOOTLOADER, Recovery mode, Power off.
I tried the Recovery mode option and I only see the word GOOGLE with no further activity.
What is restart BOOTLOADER?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
As the name implies, it'll restart the bootloader. To the get a better understanding of what lies behind Android's bootloader menu you might want to check out this tutorial.
Seems like other users had the same problem, in this page are listed some methods that could work, how I'd go about it all depends on whether you need to keep the data or you're just good with making your tablet work again. Wiping Cache and tapping the back of the device are both quite safe and you can simply give them a try. The other 2 methods listed are more destructive, in the sense that though Wug's Toolkit and factory resetting may solve the issue, all unsaved data will be lost if not backed up before-hand (I checked the FAQ and the Toolkit does actually have a "No Wipe Mode" option, but I'm not sure it can apply here).
For any other questions feel free to ask, and let us know if any of these methods worked for you
Nexus 7 Bild
Anleitung
Asus Google Nexus 7 / 2012 - Werkseinstellung
Schwierigkeitsgrad:
Sehr einfach
5 minutes
Android Phone Bild
Anleitung
Bootloader, Wiederherstellung und die Freude am Entsperren mittels eines Android-Telefons
Schwierigkeitsgrad:
Mittel
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Jennifer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 34
Letzte 30 Tage: 178
Insgesamt: 1,869
