Zum Hauptinhalt wechseln
Veröffentlicht im November 2020. Der Mac Mini nutzt Apple's M1 SoC mit einer 8-Kerne CPU und einer 8-Kerne GPU. (Model Axxxx/EMCxxxx)
Device stalls at Choose Startup Disk - no options provided, spins
At power on, system chimes, logo briefly appears, then Choose Startup Disk. Select the system you want to use to start your computer has no options. Spinning circle, Restart button grayed out. Also does not recognize bluetooth mouse. Using plugged in keyboard. Tried commands and power up options with no difference. Will not enter any type of recovery. Keyboard worked initially to select language. Thought of installing new HD but see that is not an option. Am I left with a brick?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Sadly, there is no removable drive in this series the new M1/m2 based systems have soldered RAM and flash storage.
You could try booting up using another dive which had the required macOS on it using the Option (⌥) key
Reference: Mac startup key combinations
Otherwise it's time to visit an Apple Store to see what they can offer you for help. Sorry ;-{
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Dennis R Tokarski wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 671
