Zum Hauptinhalt wechseln
Whea Uncorrectable error in my old pc
Hey,
Pc specs
Processor -Intel core 2 duo e7500 2.93 ghz
Ram- samsung ddr2 2gb×2 ram
Motherboard - Asus p5kpl-am in
Psu-230v
Graphics card-Intel integrated g31/33 express chipset family
Storage- crucial 240 gb SSD
So,as of my specs my pc is really old...
When I was using it normally 1 week ago it started showing bsod's.I tried every possible way to fix it but I couldn't and I don't want to spend money
I came to that something called genuineintel.sys is causing this WHEA UNCORRECTABLE ERROR (with the help of who crashed software)
Please help me,I study from that and if it does like this everytime I can't study
Help me🙏🙏
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
So that error likely tells me you have an Intel CPU...Not to worry, I have some ideas.
So first off, make sure that the CPU isn't being overclocked. You can check in your BIOS or if you have software that allows you to change the clock speed, I would make sure it's at the default speed.
I would also run a diagnostics check on the processor
And let's say that your computer wasn't overclocked and the check passes. Most likely it's a bad driver or your BIOS might need an update.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
My pc is so old that I don't think they have any bios update and I don't think my cpu is overclocked...Please tel how can I check if it's overclocked or not
von
And the processor is not detected by that Intel processor diagnostic....
I've searched on the internet and this is because my processor is so old
von
I fixed that Whea but two new bsod came that are *Driver irql not less or equal and irql not less or equal* along with Unexpected kernel mode trap something like that
von
Try this steps to fix-
Get all the latest updates with Windows Update. Go to Start > Settings > Windows Update , and then select Check for updates.
Try restoring Windows back to an earlier point in time.
Regards,
Rachel Gomez
Bewertung 1
1 Kommentar:
I have reinstalled os hundreds of time so I don't have any restore point
von
Antwort hinzufügen
Playersir5519 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 852
