Zum Hauptinhalt wechseln
A2115 / 2020 / Prozessoren beginnend mit 3,1 GHz 6-Core i5, bis 3,8 GHz 8-Core i7. Markteintritt am 4. August 2020.
42 Fragen Alle anzeigen
iMac freezes at password entry
I have an older  27” imac  running Majouve 10.14.6.
It  has 32 MB of memory.
It has run flawlessly since new.
A few days ago, whenever I moved the pointer, I got the Beachball for a few minutes. This only got worse. Then when I restarted it,  It gets to the password request – when I enter (and I know that I am entering the correct one) it freezes. But it doesn’t shake , like it does when a wrong password is entered.
Are there any suggestions as to the cause ?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
What is your drive config? HDD, SSD or Fusion Drive. What is the size/s of the drive/s internally.
von
Some info about the specific model would be helpful as well as the type of storage drive in it (if you don't know the capacity and what model it is can help pin that down.
von
Einen Kommentar hinzufügen
1 Antwort
Shut down your Mac, then start it over. Immediately press and hold Option, Command, P, and R. Then you can release the keys in about 20 seconds. After your Mac successfully reboots, you can open System Preferences and adjust any settings that were reset.
Regards,
Will
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
@willjoe - Resetting the NVRAM won't help here.
von
Antwort hinzufügen
Bill Crandell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 40
