Zum Hauptinhalt wechseln
Modell A1312 / Mitte 2011 / 2,7 & 3,1 GHz Core i5 oder 3,4 GHz Core i7 Prozessor, ID iMac12,2
697 Fragen Alle anzeigen
Is there a tutorial for the logic board replacement?
Is there a guide out there on how to replace the logic board?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@civil35 this guide IMac Disassembly should work for you. To remove the logic board you do not have to follow all the steps just remove:
• Glass panel
• LCD panel
• Power supply
• AirPort card
• Backlight pressure wall
• Optical drive
• Optical fan
• IR board
• Memory
Note: The SSD-only CTO option has a hard drive power plug, on the back of the logic board. It shorts out the HDD power when no HDD is present. Transfer this plug (922-9877) if replacing the logic board.
This is a comment only since the snippet of the disassembly needs to be verified by you. Let us know if this worked for you .
von
Einen Kommentar hinzufügen
1 Antwort
iMac Intel 27" EMC 2429 Motherboard Replacement
This is the closest I can find. This guide is still in progress, so be careful.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
John Myers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 36
