Zum Hauptinhalt wechseln
Galaxy S smartphone from S20 family. Featuring a triple camera with AI, Infinity O display, LTE and WiFi 6 with 5G capability. Available in six new colors.
22 Fragen Alle anzeigen
The reason for the appearance of moisture in the charging port
When charging it gives me the presence of moisture, which is the origi
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Me too. After much searching I believe the charging port is bad and needs to be replaced. Mine has had the moisture detection for a month now and I've tried everything like silica gel packets to logging out of and into my Samsung account (which seemed odd.) I even used a toothpick very gently and got dust out. I also tried a small empty brand new liquid container with a small diameter circle top that fir right into the charging port and blew it out for 10 minutes.
Now I am here to find a charging port to replace mine. Replacement units that are used or certified refurbished are going for $150-$190 on reselling sites. I believe this part is about $20 and you need an hour or so for replacement time depending on your skill level. I have replaced touchscreens, batteries, and buttons. I believe I could hopefully do this in about 45 minutes. If it works or not I'll try to come back here as you have already been waiting a while. -James
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Try blowing out debris from the port with a can of compressed air. Amazon sells compressed air at the link below:
https://www.amazon.com/Falcon-Compressed...
War diese Antwort hilfreich?
Bewertung 1
Have a new charge port fitted.
Bewertung 1
Antwort hinzufügen
hussein ali wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 143
