Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Jagjit Singh you are not giving people a lot to work with. How are you charging? what have you checked? Your Charger? Your charging cable? Cleaned the charging port? did anything happen to your phone prior to this? If it is the one X then replace the battery.
Charging port
von [deleted]
von oldturkey03
