Zum Hauptinhalt wechseln
Das Flaggschiff-Smartphone von Huawei erschien im April 2019. Es hat ein 6,47 Zoll FHD+OLED Display, eine Hauptkamera mit 40 MP und 8 MP Telekamera und einen neuen Ohrlautsprecher. Der Fingerabdrucksensor befindet sich im Display,
43 Fragen Alle anzeigen
microphone not working for 10 sec
I have a problem with my P30 pro. When I call somebody or somebody calls me it takes 5-10 second for my microphone to start to work. I called service and they say it is bottom board with microphone. I changed bottom board with microphone and it is the same. Any idea what can be wrong?
Ist dies eine gute Frage?
Bewertung 2
3 Kommentare
did you solve the problem...i have the same problem
von
No i didn't, nothing works I will try with Huawei service if they can repair it.
von
managed to find a solution?
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Hi @blisk1
Try using the phone in safe mode and check if the microphone now works OK when on a call.
If it does then a downloaded app might be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one and test the phone in the "normal" mode between each uninstall. When it works OK the last downloaded app that was uninstalled was the cause of the problem. A downloaded app is one that you downloaded and installed on the phone and didn't come pre-installed with the phone.
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
Thank you for the advice but it is the same in safe mode, mic doesn't work for 10 sec. But it works when I use phone in speaker mode.
von
@blisk1
You may have to try a factory reset.
Be sure to backup the phone either to the cloud or a computer, using the phone's backup feature in Settings before performing the reset.
If it works OK after the reset then you can restore the phone to what is was before by using the phone's restore feature in Settings.
if it is still faulty after the reset it is a hardware problem.
Since you have replaced the bottom board it looks like it may be something on the mainboard but this is just a guess
von
Factory reset didn't help. It only help to loose all settings of my apps
von
I will try this. I also had my phone on service for Huawei twice and it works for few months and than it is the same.
von
I tried safe mode and it doesn't work it is the same
von
Io ho lo stesso problema, se dai un colpo a sinistra della camera superiore incomincia a funzionare, forse è il flat interno.
Google translate:
I have the same problem, if you give a swipe to the left of the upper chamber it starts working, maybe it's the internal flat.
Bewertung 0
1 Kommentar:
Ciao, sei più riuscito a risolvere poi?
von
Because you already opened the phone and removed the microphone pad or maybe it fell when you opened the phone
Bewertung 0
1 Kommentar:
no it didn't
von
I discover the problem. You have changed bottom board with microphone that first step now you have to change the flex cable wich conects the bottom board and the main board thats the flex with the charging port to. You change that and your problem is fixed
Bewertung 0
1 Kommentar:
I had the phone 2 times on huawei service and after that it works few months than it is the same
von
Antwort hinzufügen
Damjan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 230
Insgesamt: 3,015
