Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
Ist dies eine gute Frage?
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
War diese Antwort hilfreich?
Thanks
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 292
7 Kommentare
Is this a necessary component?
von Brad
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
von Arnoud
do you mean on back of motherboard or on inside of rear case???
von pollytintop
Inside of rear case behind battery....
von Arnoud
Slide 30 in changing the rear case gives a good view.
von Arnoud
2 weitere Kommentare anzeigen
