Zum Hauptinhalt wechseln
Aktualisierte Version des Retina MacBook 2015. Modell A1534, EMC 2991.
Kein ton nach Akku tausch
Nach Akku tausch war das Audio Flexkabel nicht ganz eingesteckt: kein ton. (aber leiser startup chime)
erneut geöffnet, flexkabel korrigiert, alles OK.
Nach Neustart oder Ruhezustand wieder kein ton, auch kein chime.
Flexkabel neu plazieren bringt nichts.
Frage:
Wie kann ich feststellen ob Audio board oder logic board oder das flexkabel selbst das problem ist? (Optisch scheint alles i.o.)
cheers!
Ist dies eine gute Frage?
Bewertung 1
9 Kommentare
@cstanner do you have sound when you connect some headphones?
Translation
@cstanner hast Du sound, wenn Du einen Kopfhörer anschließt?
von
hi,
no, sound board is not recognized (not shown in audio settings, strike through audio symbol)
von
hi , sounds like it cannot find your audio board. Check this guide https://de.ifixit.com/Anleitung/Retina+M... schritt 16 and 17 and make sure that cable is properly inserted. Just verify that it is. Make sure everything is properly connected and that the cable is properly inserted. Have you done an SMC reset already?
von
Ok, did it once more.
Dis- and reconnected the audio on birth sides of the ribbon
SMC ( and PRAM for good measure) reset
Still nothing.
Is there a way to know if either the audio board or ribbon connectors or logic board are faulty?
von
@oldturkey03 I really appreciate your time, thanks!
Not sure how to get the thing running in a position to use any multimeter though, I'll give it a shot.
Re the Board files: overbearing gdrive wont let me download the .exe
"Sorry, this file is infected with a virus.
Only the owner is allowed to download infected files."
von
4 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@cstanner the strange thing is that this all started after you changed the battery. I would have thought that at most this would be caused by a bad connector. Yes, it could be the flex but what I do not like is that your audio is not even recognized. Anyhow. If you need to get really deep into this, you can check the connector for signal/power. J6799 is the connector where the flex connects to.
Looks like 5V on #5 1.5V on #17 and 3.3V on #10
No information available on the audio board yet.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Christian Stanner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 145
