Zum Hauptinhalt wechseln
Modell A1312 / Mitte 2011 / 2,7 & 3,1 GHz Core i5 oder 3,4 GHz Core i7 Prozessor, ID iMac12,2
697 Fragen Alle anzeigen
CPU Fan 0 RPM, Apple Hardware Test Error 4M0T/4/40000002: CPU-0
I bought this iMac used with a broken CPU fan (Macs Fan Control says 0 RPM) and CPU overheats easily . I bought and installed a used CPU fan off Ebay, but it didn't fix anything. I've already tried resetting SMC.
Is it possible for me to tap the CPU fan connector wire into the ODD fan connector or the HDD fan connector? (It's actually an SSD now.) I'm willing to remove the power from the other fans if you think that 1 socket on the logic board shouldn't power 2 fans. Thanks!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
yes!! yes I have this setup right now when the HDD fan connector blew so im using the power from the ODD fan connector to power both fans !
its been like this for nearly a year and never had an issue
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks so much for the reply Teddy. Could you let me know how to do this? I have little knowledge of electricity and soldering, etc.
von
Antwort hinzufügen
Adrian Phan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 65
