Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
151 Fragen Alle anzeigen
The sound on loundspeaker not loud enough
After replacing my first charger port on iPad 6, the sound on loudspeaker is not loud enough. Is replacing the charger socket affect the loudness of sound? Is there anyway I check it?
Thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi Viet,
First of all, congratulations on a difficult repair; that charging port replacement is something I'd definitely have second thoughts about attempting!
Going over the steps required to pull the motherboard, it appears you have to unplug both speakers as part of the process. My strong suspicion is that one or both of the flex cables connecting the speakers to the lighting flex may not be fully seated. With those ZIF connectors you can't always tell for sure the cable is fully seated. If it was mine, I would open it back up again and reseat the speaker connectors.
Unfortunately, both of those speaker cables are ultimately routed through the lightning flex, so if reseating the speaker cables doesn't help, the the next obvious source of problems would be the solder job on the motherboard. Ouch, hope that's not it, so check those speaker ZIF connectors first.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Viet wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 9
Insgesamt: 28
