Zum Hauptinhalt wechseln
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
pressure release valve leaking
how to replace the valve
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi @tongrick,
What is the make and model number of the water heater?
Have you operated the release lever on the pressure relief valve so that it opens to release the pressure in the tank, then release the lever so that it closes again and check if it stops leaking?
It may take a few minutes to stop dripping until it finally closes fully again.
von
Einen Kommentar hinzufügen
1 Antwort
pressure relief valves do develop leaks and can be easily replaced. However, after my neighbor did that his tank started leaking. The two were not connected, the heater was just old.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thank you for the answer.
von
Antwort hinzufügen
RICHARD TONG wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 187
