@jay99 for now I'd go and check a few things according to the general 7000 series SM. I would use the troubleshooting for the "Engine runs but misses" troubleshooting
Engine Runs But Misses
● Carburetor adjusted incorrectly.
● Engine overheated.
● Faulty spark plug(s).
● Ignition module(s) faulty or improperly gapped.
● Incorrect crankshaft position sensor air gap.
● Interlock switch is engaged or faulty.
● Loose wires or connections that intermittently ground ignition kill circuit.
● Quality of fuel (dirt, water, stale, mixture).
● Spark plug lead(s) disconnected.
● Spark plug lead boot loose on plug.
● Spark plug lead loose.
Choose things that could have happened by a bit of impact. See if this manual Kohler 7000 SM will help you to narrow it down
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
4 Kommentare
@jay99 you have a complete engine number? I wonder if the "timing" got knocked out of whack
von oldturkey03
@jay99 One possibility is the timing being off, like @oldturkey03 said. That is rarer though, because hitting a root with a zero turn (I’m assuming that’s what you have) shouldn’t be anywhere near enough to knock timing off. Had it been a walk behind (push) mower, absolutely, because those have the blade directly on the engine axle. (That’s why they use flywheel keys.)
A complete engine number and mower model would help.
von Geir Ove Andersen
It says kt730
von Jay
@jay99 the attached SM in the answer will cover your model
von oldturkey03
