Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
Why is there a box around everything I click?
Every time I click something, a black box pops up around it and it is very anoying.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 42
15 Kommentare
It won't work
von
Its Driving me FRIGGIN LOOH LAAAH!!!!! Trying to fix it for 2 hours now, had problem also with someone constantly reading text and app covers on home screen non stop over 50+ Apps, reading them @ 90mph lol. Now just left with this stupid box!!! I have actually changed so many settings by accident on the phone cos the box has a mind of its own bouncing all over the screen, that if I do fix it , I wont know What's what n b like F*** where is everythin ????
von
Thank you! I went to General, then to accessibility and last to "Voice Over". Turn off and turn back on... This is how I fixed the annoying blue box and clicks. Thanks for the tip.
von
i have this problem too! i turned it off, and turned it back on. now it won't let me put in the password. help!
von
Well i cant actually get into my phone because its on activation lock and i know my apple id email but i dont know the password so whenever i go to reset it i cant because it ask for the old phone number of that phone but i dont know it.
von
10 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
7 Antworten
Gewählte Lösung
Sara, it sounds to me like you have your Voiceover on "When an item on the screen is selected, a black rectangle called the VoiceOver Cursor appears around it. The VoiceOver Cursor is displayed for the benefit of sighted users with whom you may be sharing your iPod touch. " Turn VoiceOver on or off: Go to Settings > General > Accessibility > VoiceOver. Download the manual from here starting on page 119 it will tell you all about it. Hope this helps, good luck
War diese Antwort hilfreich?
Bewertung 24
26 Kommentare:
I REALLY HOPE this works. I have the same problem, thanks in adavance
von
OT, could this be the answer to this question? Has artifacts attached to the desktop icons and mouse pointer..
von
I can't scroll tho
von
I can't scroll down
von
thanks very much ey...it worked on my Ipad
von
21 weitere Kommentare anzeigen
Hilfreichste Antwort
Hit the home button 3 times... it will work!
Bewertung 31
16 Kommentare:
perfect! thanks
von
thx very very mutch
von
Thank you so much for the help
von
Worked straight away - thanks for your help :)
von
thank you so much!!!!!
von
11 weitere Kommentare anzeigen
Ask Siri to turn off voice over. It worked for me.
Bewertung 4
9 Kommentare:
I have iPhone 4 I phone 4 doesn't have sir
or does it
I dunno
von
I meant siri
von
my siri is not listening very well
what do I do now!!!!!!??????!!!??!?????
von
Sir I is not responding
von
I have an iPhone x. This worked. Say, "Hey Siri" then "Go to Voice Over". You'll be able to turn it off even if your screen doesn't allow you to by saying "Turn Off Voice Over". Immediately able to touch my screen again without the glitches or annoying boxes surrounding every little thing on the screen that I touch. You can try double tapping the item but mine didn't always work.
von
4 weitere Kommentare anzeigen
Hold your home but ten for three long holds
Bewertung 3
3 Kommentare:
what home grace
von
I found my pld ipod mini. Hiw do i fix that?
von
Not sure but try holding home button and on off bottom at the same time for 30 second
von
Like the other answers, pressing the home button thrice worked! My friend lent me his iPad and I let my cousin play the iPad. After, she left it on the drawer. I checked it and it does not work! It illuminates the screen but nothing shows up. But then I saw an answer that said to tap the screen with three fingers and it turned on "'BUT"' whenever I tap anything it squares the tapped thing. So the technique worked! I am thankful to the others who helped me since it saved me from getting grounded "'AND"' getting fined as well.
Bewertung 0
2 Kommentare:
It just keep asking for password code for siri but when I type a code it doesn't work
von
Hmm thrice!
Juliet is the sun.
Arise fair sun and kill the envious moon
von
Just hold down button for Siri and say, "Siri, turn off "Voice over in settings". My phone was instantly restored and back to normal.
Bewertung 0
1 Kommentar:
Worked on the first try with Siri assist.
von
I have an LG and it has a voice to it and there a green box over when I hit everthing and it wont let me swipe. or nothing how do I make it go away????
Bewertung 0
Antwort hinzufügen
Sara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 45
Letzte 30 Tage: 197
Insgesamt: 164,203
