Zum Hauptinhalt wechseln
The Samsung Galaxy S5 Sport is Sprint-exclusive and designed for fitness enthusiasts.
Phone will not turn on.
The button to turn on my phone has stopped working (right hand side at the top). Phone is fully charged but will not turn on.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi,
Try a power refresh and check if that resolves the problem.
  • Remove the battery from the phone and then press and hold the Power On button for a full 30 seconds and then release it.
  • Reinsert the battery and then try pressing the Power button and check if it turns on.
Here's the ifixit Samsung Galaxy S5 Sport Battery Replacement guide that will help.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thank you for your answer. My problem is that the power on/off button no longer works. Is there any other way to turn on the phone?
Regards,
Andrew
von
The easiest way to do this would be to replace the power button flex cable (supplier example only - search online for "G860P power button flex cable" to find suppliers that suit you best)
Here is a video that may help
von
Antwort hinzufügen
Andrew Blackwell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 139
