Zum Hauptinhalt wechseln
Das OnePlus Nord ist ein Smartphone der Mittelklasse, erschienen 2020. Es ist mit einem 6,44" 90 Hz Fluid AMOLED-Display ausgestattet, drinnen arbeitet ein Snapdragon 765G mit 8/12 GB RAM, einem 128/256 GB Speicher und hat vier Rück- und zwei Frontkameras.
20 Fragen Alle anzeigen
How to clean dust in front camera?
Hey there, I've knocked around my OnePlus Nord phone a few times and I have had the front screen pop out just a bit from the corner a couple of times but now I can see dust underneath my screen and I'm wondering whether it would be safe for me to just open the front screen, get some compressed air or a microfibre cloth and just try to clean it off. I'm pretty sure I'm out of warranty on my phone too. If I'm going to do that, what tools do you think I would need and what tips should I take before doing it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
"front screen pops out just a bit from the corner" Can you provide pictures of it in that state? Or can you carefully lift the screen with a toothpick and take pictures of the dust area?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi
To clean the front cameras you need to take the screen off first
Here’s a guide for that
OnePlus Nord Display tauschen
As for cleaning the cameras them selfs I recommend using a cotton bud/Qtip with some isopropyl alcohol
When cleaning make sure to be careful because cameras are extremely delicate
For this repair you will need basic screwdrivers,suction cups and pry tools
Ifixit sells a small tool kit that has these sorts of things in it
Here’s a link to it
Essential Electronics Toolkit
Also once you have taken it apart you will need to adhere the screen back on using some adhesive tape
Here’s some ifixit sells
Tesa 61395 Tape
Hopefully this helps
Any questions please ask
Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair. Bild
Produkt
$29.95
Custom cut rolls of Tesa 61395 double-sided tape for repair. Bild
Produkt
Tesa 61395 Tape
$5.99
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
thanks! will try this out and hope it works.
von
@aj_clark
Good luck:-)
von
Very nice response. I even learned about the Tesa Tape. Will have to get some.
von
@bessemerjohn
Tesa tape is the best stuff(in my opinion)
I like it because it’s double sided and very thin:-)
von
Antwort hinzufügen
Adam JC wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 1,496
