Zum Hauptinhalt wechseln
Apples Flaggschiff-Smartphone für 2020 wurde am 13. Oktober angekündigt und kam am 23. Oktober auf den Markt. Dieser Nachfolger des iPhone 11 Pro ist mit einem 6,1 Zoll OLED Display, einem Kamerasystem mit drei Objektiven und LIDAR sowie 5G ausgestattet.
What else could be wrong with my iPhone 12 Pro?
My phone got smacked by an ATV after it fell out of my pocket. I don't think it was actually run over b/c the damage doesn't look that bad.
However the screen is smashed and it won't turn on. I opened it up and it looks pretty good... the battery doesn't looked smushed or bulging.
So I bought a replacement screen because I really just want to get it to turn on so I can get the photos from the day it died. But I plugged in the screen and it still doesn't power up.
I was thinking that maybe some other parts I can't see are damaged, but before I completely disassemble it, wondered if anyone has some other things to check.
thx
Ist dies eine gute Frage?
Bewertung 2
6 Kommentare
Did you disconnect the battery before you changed the screen?
von
What does the back of the phone look like?
von
@barriphone i dont think it matters now in newer models if you disconnect the battery before replacing the screen
von
@tech_ni It still does.
von
@guardian10 im doing more consoles than phones atm so havent looked into it much
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Yikes, I think I disagree as to whether it got run over or not, lol. That's one broke phone!
Anyway, check the charging port carefully with a magnifying glass and a bright light; there could easily be dirt or debris in there keeping the plug from making good contact. You might try cleaning it with a microfiber eyeglass cloth and some 90% or higher isopropyl alcohol; a toothpick works pretty good for getting the cloth down into the port.
Once you're satisfied the port looks good (and has no bent or broken pins), try plugging it into a computer and see if it's recognized. That will tell you if it's got a minimal amount of function even if you can't see anything on the screen.
Give those things a shot and let us know what you find.
War diese Antwort hilfreich?
Bewertung 4
20 Kommentare:
Good job bro I like you’re Answers
von
Ps I voted you up 😁
von
splatkat, I think I have to agree with @dadibrokeit’s disagreement; That looks like it was both hit and run over. The funny thing: It’s actually worse for the phone to get “smacked” hard, than to be run over by a tyre, because the impact can result in forces many times greater than a tyre running over it.
If what @dadibrokeit doesn’t show any difference, you could likely be looking at board separation :( That will require splitting the logic board and further analysis.
von
thanks @dadibrokeit.
so, i did clean out the charging port as suggested and plugged it into my computer, but nothing happened.
however, i did the same thing with another iphone and before my computer would recognize it, i had to put in the passcode to unlock it and use the "accessory" (i have the phone cable plugged into a USB hub since my macbook only has USB-C ports and my phone cable is USB 2.0 or whatever) ... so since the screen on this broken phone isn't working, i won't be able to unlock it so that the computer can see it.
von
@geirandersen tire* not tyre sorry for being rude just letting you know 😁
von
15 weitere Kommentare anzeigen
Maybe the battery got dislodged and there is a way to get the info of off the phone I think search it up
Maybe some part or components got smashed this happens trace the board and tell me what you see (might need to use microscope)
Bewertung 0
1 Kommentar:
Smile
von
Camara 1x .5 not working
Bewertung 0
1 Kommentar:
What do you mean by not working? Please give us more detail if you want an answer.
von
Antwort hinzufügen
splatkat wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 438
