engine light on while driving
Why my engine light on and blinking while driving
Ist dies eine gute Frage?
Hi Leanna,
A check engine light being on is troubling enough, but when it's flashing that's bad. I mean really bad. From some random place on the internet:
There are two types of check engine light warnings that all drivers need to be aware of. The first – and more severe is a Type A misfire, which is represented by a flashing check engine light. This flashing check engine light means you are doing “mechanical damage” (read in a deep ominous voice designed to imply very large repair bills by continued neglect) to your vehicle if you continue to drive under these conditions. If you see a flashing check engine light you should seek immediate professional advice. By mechanical damage we are talking about things like the catalytic converter, the exhaust manifold, pistons, rings, valves – virtually all upwards of four-digit repair bills.
During misfire, raw fuel is being passed through your vehicle’s engine. This fuel actually ignites and starts a fire in your exhaust manifold and catalyst. This drives the temperatures up in excess of 1000̊C causing the ceramic in your catalytic converter to begin melting. It can crack your exhaust manifold, damage sensors, and much more. If you see a flashing check engine light, you need to act IMMEDIATELY to save your vehicle and a lot of money.
Don't drive the vehicle unless it's straight to a repair shop; preferable would be to have it towed there.
At a minimum you need to have the engine codes scanned to determine what the light means; that will in turn point you in the right direction as to what repairs are needed.
War diese Antwort hilfreich?
Engine oil sensor
Hendy, three words aren't enough for us to be able to help.
What about your engine oil sensor? Is there an oil indicator light one? Is your check engine light on with some kind of oil sensor code? If so, what code are you seeing? Have you had the engine codes scanned? Are you looking to replace the sensor and want help figuring out how?
Without more information for us to go on, eventually we'll just archive your question as unanswerable, so tell us more.
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 37
Insgesamt: 695
