Zum Hauptinhalt wechseln
TVmodel: LD4655VX, LED backlight, 46"
HDMI Ports Not Working w/ Amazon FireStick
No Connection to HDMI Ports on 46 in HDTV Westinghouse.Amazon Firestick is not displaying anymore I switched to HDMI 1, HDMI 3 & HDMI 2 was not connecting. Now, none of the HDMI ports are even connecting to the Amazon Firestick. No display is showing of any tv shows or programs. Blank screen!
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
Do the ports work with any other HDMI source?
von
Einen Kommentar hinzufügen
1 Antwort
The HDMI cable you're using might be malfunctioning or too old to perform adequately. Try a different HDMI cable to see if it solves your issue. Alternatively, you can use the first HDMI cable to connect a different video device to check if the video device is malfunctioning.
Regards,
Will
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
JesusChristisLord GodIsGood wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 44
Insgesamt: 288
