What's included in the Box
HDTV
Power Cord
Quick Start Guide
XRT122 Remote
Getting Started
E40-C2 Tech specs
Physical Properties Model Information
Dimensions w/ Stand: 35.71"x 22.73" x 8.27"
Dimensions w/o Stand: 35.71" x 20.57" x 2.60" Remote Model: XRT122
Packaging Dimensions: 38.82" x 24.33" x 5.12" Remote Connectivity: IR
Weight w/ Stand: 16.09 Lbs.
Weight w/o Stand: 15.43 Lbs.
Weight w/ Box: 22.05 Lbs.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar:
Hi,
Is the TV standby power light turned on?
If not have you checked that the power outlet that the TV is connected to is working OK?
Was there a storm or a power outage just before you couldn't turn on the TV?
If the standby power light is on have you checked that the batteries in the remote control are OK?
Have you tried turning on the TV using the TV controls i.e. power button on the back of the TV?
Hi,
What have you tried?
von jayeff
