Zum Hauptinhalt wechseln
A high end laptop, made from Aluminum and Carbon fibre chassis, that Dell manufactured in 2018.
New 97w Battery Replacement - Not charging past 47%
Purchased a new battery to replace my current Dell branded 97w battery. The replacement was easy, however the battery is not charging past 47% (first time) and left on over night 18 hours. I did reseat again with not luck. Also, upon removal I performed that CMOS "flea" power clear holding down the power after battery removed for about a minute. Also, thinking this battery might actually be just a little thicker than original a I'm not getting a true click motion on my touchpad. Will most likely return and get a Dell original but thought I would ask here first. Really like what this company is doing and would prefer doing business here.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
Create a battery report and compare the Design Capacity value versus the Full Charge capacity value.
For a new good battery they should nearly be the same value.
You may just have got a bad battery.
There is a 1 year warranty on the battery so if it is faulty getting a replacement should be no problem. Also explain about the "thickness" and the problem you think it caused. They may have got a bad batch who knows?
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I have same problem, any solution?
von
Antwort hinzufügen
Mark Willis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 28
Insgesamt: 500
