Zum Hauptinhalt wechseln
Das iPhone 13 mini ist eine kleinere Version des iPhone 13 von Apple und das zweite mini iPhone. Es wurde am 24. September 2021 veröffentlicht. Es verfügt über ein 5,4" OLED, einen A15 Bionic-Prozessor und ein Zwei‑Kamera-System.
After Housing Swap Apple Pay Not Working
Hello
I did a Housing swap with a wireless charging pad installed and other small parts preinstalled. Now the customer's Apple pay is not working I think it might have to do with the wireless charging pad possibly part is serialized. Has anyone else come across this issue yet? Do you know what part is connected to apple pay?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Define “not working”.
Is it just not sensing NFC, or there is an error when trying to activate a new card or paying with an existing card? Does Apple Pay in app or webpage work?
NFC is at the top end of the phone, check if you have messed up any of the top antennas and screw posts.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
I don't have the phone but those top antennas were replaced because small parts were pre-installed.
von
@consistent Probably installed wrong.
von
The nfc sensor is in the charging coil so you might have to swap that over for it to work again. When you say ‘small parts’ what was included?
Bewertung 0
1 Kommentar:
NFC is NOT in the charging coil.
von
NFC antenna is on the top by rear camera.
When you say ApplePay doesn't work, it doesn't work at all or does Wallet show up when your double click side button? If it shows up, then it's antenna issue. make sure it's connected properly and replaced NFC antenna from original housing.
Bewertung 0
If, by "not working" you mean that the customer gets the message "Unable to activate Face ID/Touch ID on this iPhone," then it is because the Face ID and Touch ID components are serialized to the logic board. They cannot be replaced. Apple cites security concerns for this, but I think it is just that Apple wants you to have one more reason to buy the latest iPhone instead of repairing your old one. #rightrorepair
Hope this helps!
Bewertung 0
Antwort hinzufügen
Mark D Schlossman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 33
Insgesamt: 1,387
