Zum Hauptinhalt wechseln
Verwendet einen kleineren Kühlkörper und einen vom Nutzer abschraubbaren Standfuß.
HDMI behind the ps5 is damaged
HDMI doesn’t work behind the ps5 anymore
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 14
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Very common problem for the PS5, Its a terrible solder job from the factory. I have repaired a few.
HDMI needs to be resoldered to the board or replaced if damaged..
War diese Antwort hilfreich?
Bewertung 8
2 Kommentare:
Was in a situation where I had to move out quick and was mad and pulled the cords fast and the hdmi port is crooked
von
How much is it gonna be
von
I have this same problem too can someone direct me on how i can fix it?
Bewertung 0
6 Kommentare:
@davidmanteaw let's see if our game console Guru @dan0 can assist you with that.
von
Hi!
Did you tried a new cable? Does the port look damaged? Can you share some pictures with us regarding the port? Thanks!
von
I checked the ports and it doesn't look damaged. Regarding the pictures i do not know how to share it here because im new to the site
von
@davidmanteaw unless you're good with liquid metal and soldering id find a reputable repair shop and have them do it. For some reason sony decided to use liquid metal as apposed to thermal paste. If you're not careful it can get everywhere and possibly kill the board.
von
Alright @Ted i think ill do that. I wanted to fix it myself to see how id go about it. But because im highly inexperienced i think your suggestion is much better
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
sfwjojo382 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 68
Letzte 30 Tage: 335
Insgesamt: 6,760
