Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für Wasserenthärtungsanlagen.
Shot in the dark for Hall Sensor for Culligan
I have a Culligan Gold series watersoftener. My unit can measure water flow. The way it does this is through a hall sensor that measures a small impeller that spins as the water flows. There is a magnet in the impeller that is read by the hall sensor.
I have tested the sensor by digging it out of it's epoxy bed and injecting 5 volts, it seem to be bad. I can't read any markings on the sensor. I don't know if it's a north or south sensing. (I don't know anything about hall sensors, only what I have learned in the last few days. I want to solder in a new sensor. It's about 4mm wide.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
What is the model number of the water softener device?
You may have to trawl though sites like this to hopefully find a suitable replacement.
If you see a suitable image of one in the list, click on it and you will find the datasheet where all the specs are shown for the component
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thanks Jayeff. I orders a small bundle of parts from there. At a dollar or two per sensor I can afford to mess around for a while. Watersofteners manufacturers still charge Ferrari prices for very simple parts.
von
I just found a replacement at a culligan dealer. $180!! for a 2 dollar sensor on 12 inches of wire.
von
@ alan
Did you see the part at all?
If so no doubt it was fully encased so you couldn't see the part number of the sensor.
Bit rich for just a sensor. Wonder how the price of it compares to the overall cost of the system?
Suppose it's like auto parts.
If you assembled a vehicle from parts it would be 3 times the cost of a new one ;-)
von
Antwort hinzufügen
alan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 487
