Zum Hauptinhalt wechseln
The spiritual successor to the Chromebook Pixel, the Google Pixelbook was unveiled at the 2017. Made by Google event, and made available October 31st, 2017. Model number: C0A.
18 Fragen Alle anzeigen
How to repair Pixelbook wireless
Google says it's outside the warranty period and it's a wireless hardware issue.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi @sabinagmail
What is the problem with the WiFi?
If it is turning on but not connecting to a network, then it may be an antenna problem, loose or disconnected perhaps. Try using the laptop as close as possible to the network router e.g. <10cm, and check if the WiFi works OK.
If it does, here's the ifixit Google Pixelbook Motherboard Replacement guide. At Step.24, the antennas can be seen being disconnected from the WiFi card.
If there are other problems with the WiFi and you've proven that it is a hardware problem and not a software problem (powerwash?), the WiFi module (Intel 7265D2G) is soldered onto the motherboard so it won't be easy to remove.
Searching online for a replacement WiFi card produced no results.
Unfortunately I was also unable to find any USB-C WiFi dongles that you could use to connect to the laptop so that you could have WiFi capability again.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thank you! Will try it.
von
Antwort hinzufügen
Sabina wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 3
Letzten 30 Tage: 9
Insgesamt: 62
