Zum Hauptinhalt wechseln
Mavic Mini supports 12MP aerial photos and 2.7K Quad HD videos. A 3-axis motorized gimbal provides superior camera stability and ensures clear, ultra-smooth footage. The quadcopter weighs up to 250 grams. Model: MT1SS5.
Help with lost mini resistor
Hi.
I managed to lose a mini resistor when I was replacing the gimbal cable after a crash with my DJI Mavic Mini...
Could you help me with the information about the resistor? It's the one on the outerside by the connector of the flat gimbal cable on the mainboard. I've attached a picture showing it.
Regards Lars Jonsson.
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi
Unfortunately I don't have board to take reading for that resistor however,if you have a multimeter we can do some tests to see if its necessary
what to do is put the metre into continuity mode and put one probe on the metal part of the metal shield(or the screw hole) beside where the resistor goes and press the probe onto the pads and see if it makes a beep noise, if it does there could be a chance that its not necessary as it could be connected straight to ground ,if that were the case you could solder a small piece of wire over the 2 pads
if it isn't connected to ground you will ether need a schematic or a donor board to get the part from
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Lars Jonsson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 173
