Making the volume louder than the manufactured setting.
I have my volume all the way up. How do I make the phone even louder?
Ist dies eine gute Frage?
@michael4114 if you want more volume then the phone is designed to provide, all you have to do is to redesign the logic board circuitry. Design it around the audio amp and the audio codec IC to whatever power that you need it to be.
As you can see this is just not an easy question to answer. If you need bigger volume, get a Bluetooth speaker set up. You can then "crank it up" to your hearts contend.
War diese Antwort hilfreich?
I use a UE Boom3 Bluetooth speaker, if you get a second you really can amp it up pairing them
You really can’t push the internal higher as it will fail.
Hi
As well as the amazing answers from @oldturkey03 and @danj you could also get a external amp and DAC for your phone and use it with headphones
Hopefully this helps
Any questions please ask
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 255
