How do I fix a broken stick piece on the Switch ProCon?
I was finished changing Pro Controller shells until I found the right stick feeling crunchy when I clicked it. After clicking, the stick would often get stuck on the right side, and when I opened the controller again, I found this part popping out when the stick was pressed. If this is part of the problem, how can I go about fixing it?
Ist dies eine gute Frage?
You probably caught it and pulled it out assembling it. Unless there’s damage you should be able to push it back into place until it clicks. As @tomchai says, you may need a new module fitted.
von [deleted]
