Why is it taking 3 hours to dryer clothes?
Hello, I really could use some help with a dryer issue I am experiencing. My Kenmore 11061402311 dryer takes very long to dry. I have almost exhausted the internet resources regarding a solution. I have opened the dryer up and cleaned the lint. I have reattached the dryer vents and used aluminum tape on the joints. There is definitely heat because the clothes are warm. I have been putting the clothes on high heat to bypass the chance that any wetness sensor is affecting the drying times. I put in a kitchen thermometer with a load and it read around 110-115 Fahrenheit.
At this point, I suspect the causes are either:
# a heating element is at least partially faulty (Can the heating element be at fault even if it is working somewhat?); and/or
# a sensor that regulates the maximum heat is faulty and preventing it from getting hotter (While using it on the high heat cycle instead of the auto dry cycle, could a sensor be involved that could affect the high heat cycle temp? I would assume that this cycle would automatically dry at the hottest temp; and/or
- I still have the exhaust vents installed wrong.
Thank you so much for any help that can be provided.
Ist dies eine gute Frage?
1 Kommentar
@jpm413 smart move to throw in the thermometer. Dryer temp would commonly be 125-135 fahrenheit and not over 150 fahrenheit. Does it take long on all cycles? number one is definitely airflow, so your vent is important but also that the blower works properly. Check for obstruction on that (It's amazing where lint can collect:-) The next thing what I would check is the cycling thermostat which is responsible for keeping the temps at the high level.
von oldturkey03
