Zum Hauptinhalt wechseln
Angekündigt am 9. September 2014, ist dies das erste Gerät von Apple im Bereich der Smart Wearables. Die Reparaturanleitungen von iFixit beziehen sich sowohl auf die Apple Watch (Edelstahl) als auch die Apple Watch Sport (Aluminum).
Displays Apple logo for a second then back to black.
I've got some long history with this watch and need some help from the gurus here.
History: Two or three years ago, my son was given this watch; the screen was coming off and wouldn't stay in place. I ordered a new battery and force touch sensor for it and replaced the swollen battery, sealed it back up after verifying it was working, and sent it back to him. He must have used it for a year or so, then decided to upgrade, whereupon it went into a box where it sat for another year or possibly longer.
He eventually asked if I wanted it, and I said sure, I'll take it. Once it arrived, I ordered a charger and tried to bring it up. I got the red exclamation mark in a circle with the text "support.apple.com/watch/restore" underneath it in white.
Okay, I'm thinking probably a dead battery by now, given how long it's been sitting, so I ordered one from iFixit. Put it in and tried to charge it; after that it would show the Apple logo for a second then shut back off. I tried every internet solution there was out there for button presses, reseating the battery connector, hard reset, three presses on the crown, etc. Finally went to try the last one which was to let the battery die. Took a two or three weeks as I recall, but it finally did.
Back on the charger again, eventually started showing the red snake, which turned green when it was on the charger, but from there it was stuck. The snake would never go away; I could sometimes get the apple logo for a second with a hard reset (both buttons held down) but it would go right back to the snake afterwards. Spent another couple of months fiddling with it again, but never could get it to do anything else.
Finally requested a replacement battery from iFixit, which they shipped out promptly. With the new battery, I was back to the apple logo again, at least. Once more went through all the internet solutions, but no change. Let it die again, which took something like another two or three weeks, but eventually it started showing the red snake and finally wouldn't turn on.
Back on the charger again, and in a while it showed the green snake while on the charger, then red when off, but it seemed to continue to charge, as the snake went away and now it's back to the one second Apple logo and back off again.
So that's where I'm currently stuck at. If it was an iPhone, iPad or iPod, I'd do a restore, but with the watch not having been paired to a device, there's no way to connect to it to do a restore.
I'm out of ideas, so I'm hoping the iFixit community can help me out. I've been looking at the possibility of an iBus S1 programming cable, but honestly the $70 or $80 it's going to cost me is putting me off, especially when I get buy a working watch for less than that; there's one on eBay right now in good condition with charger and extra watch bands for $59.
I admit I just don't want to accept defeat, but I'm having a hard time with the idea of buying a tool that costs more than the watch is worth.
What do you guys think, any ideas for me?
Update (01/21/25)
This isn't so much an answer as it is an update with the hope that someone has some suggestions.
The watch has been relegated to a box as the only other thing I could think of to do was to purchase an iBus S1 adapter that would allow me to connect the watch to a computer and use iTunes to do a restore. That was put on hold due to the cost of the iBus adapter, so I set up an eBay search and let it run for the last couple of years. I just couldn't justify paying more for the adapter than what I could buy a perfectly functional Watch.
Welp, the search finally paid off and I picked up the S1 at a reasonable cost. I was able to plug the watch into my computer and see it come up. When I click on Update, however, it doesn't go to the Apple servers, but rather opens up a file open menu looking for an IPSW file (which, of course, I don't have).
I then went and downloaded 3uTools, which gave me a little more information. What I found is that the watch is stuck in Recovery mode. I can click the button to exit recovery mode, but it just comes back up in recovery mode again. It turns out that I can actually get it into DFU mode as well, but once you exit that, you're back in Recovery mode.
So I went looking through the Flash options on 3uTools, with no luck for the simple reason I can't find an IPSW file for that watch. At this point it appears there are no longer any firmware updates left that are signed for the watch1,2 version. As far as I can tell, the Series 3 is the oldest that can still be updated with iTunes, and also the oldest one available on 3uTools.
The last resort I can find is the company called MFC that makes and/or distributes the iBus adapters has software and IPSW downloads that may be able to get this watch updated, but now I'm right back at the same point where I can't justify paying $79 USD for a license when I can buy a fully functional watch on eBay for around $50, some as low as $35.
So, any ideas out there? Is there a way to update the watch without a signed IPSW? Is there a software tool I haven't found yet that can do the job for less than the cost of a watch? Have I missed anything? I'm certainly open to ideas at this point.
P.S. I happened to pick up both an iBus S1 and an S2 in case anyone needs the use of one, I'd be happy to help.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Sadly, it does sound like you got a bad battery.
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
Well, yes, which is why I got a replacement. It now seems to be charging past the red snake, but I'm still stuck on the Apple logo.
von
@dadibrokeit - What does the linked iPhone show?
I had thought you where still stuck on the charge.
von
@danj My son unlinked it from his phone when he put it in storage so it wasn't linked to any phone when I got it, and since I've never been able to get it to boot since it arrived, there's been no way to link it. I've run through the procedure with my wife's iPhone (I'm on Android myself), but the watch doesn't show up on the phone.
von
@dadibrokeit - Sorry don’t have any answers.
von
Antwort hinzufügen
Jerry Wheeler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 25
Insgesamt: 321
