Certain Buttons Won’t Work
The 1,5 and subtraction button on my calculator won’t work. Can this be fixed or should I just buy a new one?
Ist dies eine gute Frage?
Hi,
Use a Q-Tip lightly moistened (not dripping wet) with Isopropyl Alcohol 99%+ (available at electronics parts stores) to clean the contact surfaces of the board for the buttons that don't work.
Do not clean the contact surfaces of the buttons themselves as you may remove the conductive coating from the underside of the button.
Here's the ifixit Texas Instruments TI-30Xa Teardown guide that will help. Go to Step.5 to view the image of the board showing the button contacts on the board.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 209
3 Kommentare
A goggle search shows current (2022) prices between $13-$22. Electronic calculators in general are not repairable.
von F Dryer
@notbroken oh ok thanks
von Papaya Bear
@Papaya Bear
I suggest that you have a look at the excellent answer from @jayeff below:-)
von HelloMacOS
