Zum Hauptinhalt wechseln
Dritte iPad Generation, 4G fähig, Modellnummer A1430, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
Ipad 3 distorted crackling static noise when trying to play ANY sound.
Ok so I got an Ipad 3 3g (A1430) for repair I changed the battery and the speaker because it wouldn't make any noise when trying youtube or notification sounds, I was testing all new components, the battery its ok but the speaker would only play static while trying any type of sound, I recorded how it sounds and have the video here: https://www.youtube.com/shorts/2fLYcFgrG...
I already returned the new speaker but I'm wondering if it was a bad replacement or is it something else on the logic board.
Thank you!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Visually inspect the socket on the logic board and look for discoloration or bends on any of the pins. From your description, the speaker is receiving power properly, so the problem is improper data transfer at either a pin on the connector, or in the speaker wire itself. A new speaker will certainly confirm the issue. A new logic board is always an option, but may cause home button pairing issues.
Replace a logic board compatible with the 3rd generation 4G iPad tablet. Fix processing issues like unexpected shutdowns, reboots or water damage. Bild
Produkt
iPad 3 4G Logic Board
$31.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
PsiBot wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 339
