Zum Hauptinhalt wechseln
The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
20 Fragen Alle anzeigen
Main charging ports have failed
After some time mine has stopped recharging and has gone flat.
The charger and cable seems fine when checking with a multimeter
When connected with the dock/keyboard it does not charge
When not connected with the dock/keyboard it does not charge
At no time do I recall any sign or smell of burning
How can I charge my TF-300 for further investigation into fixing?
Is there any way to charge my TF-300 through the USB-1 port? Like I have seen other devices charging through a USB-3 port?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@fuzzoffury according to the manual you can. "Charging through the USB port may take a longer time to complete. If your computer does not provide enough power for charging the ASUS Transformer Pad, use the wall outlet instead" Time to repair your charging ports :-)
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
There seems to be a misunderstanding
Can I charge into the usb-1 port on the opposite side from the port usually used for charging on the dock/keyboard?
No matter where the power is charging from?
von
@fuzzoffury Your computer commonly only supplies around 500mA on the USB port which may not be enough to charge the tablet.
von
Antwort hinzufügen
Mark Rienits wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 93
