Zum Hauptinhalt wechseln
Hyundai's entry-level vehicle. It's available only as a sedan; the hatchback was discontinued after the 2017 model year.
Hyundai accent 2019 ... why does the ABS alarm lights after a rainy da
Hyundai accent 2019 ... why does the ABS alarm lights after a rainy day?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
ahmedhadiabbas1968 it is possible that one of the sensor wires got shorted out. You want to check those sensors/wires for corrosion as well. There is also a possibility, that the rain water carried enough debris with it that there is muck and debris on the sensor. Cleaning it should help. Ultimately, I suggest that you get the OBD on your Hyundai scanned and see what codes pop up. Anything else will really just be a guess.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
ahmedhadiabbas1968 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 220
