Zum Hauptinhalt wechseln
{A1989 / EMC3214}—Erschienen im Juli 2018. Das 13" MacBook Pro ist mit Quad-Core i5 und i7 Prozessoren und Intel Iris Plus integrierter Grafik ausgestattet.
181 Fragen Alle anzeigen
When I open the lid, screen fades to white and goes flickery
When the lid is opened past 30 degrees the screen starts to fade to white and flickers untill you can barely see what is on the screen.
When you close the lid back to 30 degrees its like a switch and screen comes back to normal.
Otherwise works perfectly. Works to external screen ok.
I know older machines had probs with screen cable but they seem to result on screen going black.
Thanks in advance for any help
2018 macbook pro A1989 i7 2.7GHz 16Gb ram
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes, the older 2016/17 systems had a backlight cable issue what was called FlexGate!
In your case the issue is within the T-CON board and the LCD panel. There is a set of cables which connect between them so the board can paint the screens image. The reset signal is not working so the screen just additively adds the following image on top.
Sadly, you’ll need a new display assembly MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly and here’s the guide MacBook Pro (13 Zoll, 2018, Touch Bar) Display tauschen
MacBook Pro 13" Retina (Mid 2018-Mid 2019) Display Assembly Bild
Produkt
$449.99
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Hi
I believe you have a issue called "flexgate" ;-{
Flexgate is where the screen cables start to break apart and perish
I was testing a A1989 MacBook Pro's screen a day or so ago and it had the exact same issue as what you are reporting
unfortunately the only long term fix is to ether have the display cables replaced which hardly any people do or have the display assembly replaced
Hopefully this helps
Any questions please ask
Bewertung 2
3 Kommentare:
I thought the 2018 model had been fixed?
I thought I would probably need new screen, ouch!!
Oh well better dig deep and shell out.
Thanks for replies
von
@alanhancock31
Yeah they ”fixed” it
In all fairness on the 2018 and above they did make the screen cables longer to try and avoid the issue but it unfortunately does still come about it’s just not as common
von
@hellomacos @alanhancock31 - Here’s a good write up on FlexGate https://www.ifixit.com/News/16943/macboo... and the 2018 onward systems don’t encounter the issue as you can see better explained here https://www.ifixit.com/News/13979/apples.... That still doesn’t mean you still can’t encounter a backlight issue! A good bang along the black clutch cover or something wedged between the uppercase and the display bottom edge (chin-plate) which is a thin piece of glass which covers the cables going to the LCD panel can be damaged. The backlight goes out, black not white
von
Antwort hinzufügen
alanhancock31 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 11
Insgesamt: 53
