Transmission has no up shift
No up shift from second gear
Ist dies eine gute Frage?
Is it an automatic? Most likely it's the Auto Trans Computer. A common problem throughout the 1990's built models. I've personally repaired thousands. Problem often starts with electrolytic capacitors and you can smell it. Leaking / exploding ones often pop the uP chip. Can also be the sensor, but you will need to measure to see if it's switching.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 33
Insgesamt: 545
Hi,
What is the year model of the vehicle?
von jayeff
