Zum Hauptinhalt wechseln
HP released this ergonomic laptop (model number 15-au123cl) in October 2016. It features Windows 10 and a touch screen.
How can I download the Hp recovery tool from a windows 7 hp
So my hp pavilion with windows 10 is not starting up the OS. I think its a boot problem or a corrupted windows os. I am trying to download the Hp Recovery Tool to a usb so i can hopefully fix the issue. how ever the laptop i am currently using is windows 7 and there is no microsoft store so i am unable to download the tool. How or where can i download the tool? or should i just get a whole new ssd.
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
I had a lady with a similar issue come into the shop. I removed the bios battery and replaced it after a couple of minutes. Pressed power and it started up straight away.
von
and how is that done never heard of this before
von
so i figured out what the battery is but how do i find it on my MB. and how hard is it to replace ??
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @erickhdez1226
Assuming that it is not a HDD problem (is the HDD shown detected in BIOS?), you can download the Win 10 installation media to a bootable USB and then when installing, (make USB as first boot option in the laptop) when you get to the setup screen, click on repair this computer link.
It should take you to the Windows Recovery Menus.
Once there select Troubleshooting > Advanced > Startup repair
Alternatively, if you have access to any known working Win 10 PC you can create a recovery USB. In the host PC go to Control Panel > Recovery > Create a recovery drive and follow the prompts. You will need an 8GB USB flashdrive and about 40-60 minutes of time (depends on specs of host PC).
Once you have the USB recovery drive, insert it into the laptop, change the laptop's boot order to USB first boot option and boot from the USB to get to the Windows Recovery Menus.
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
i do have the usb with windows os but the lap wont read anything on the usb
von
@erickhdez1226
Do you get the HP logo on startup?
can you get into BIOS OK?
Start the laptop then press Esc followed by F10
von
no i dont get the hp logo niether the windows, i am able to access the bios to change the boot order though
von
@erickhdez1226
So just confirming that it doesn't detect the USB even though it is 1st boot option is this correct?
Can't find info online regarding the BIOS settings but check if there is a USB enable/disable setting either in the Security or Advanced menus.
With some laptops you can disable USB on startup to prevent booting from a USB as a security measure.
von
it does detect the usb but it doesnt run the windows os repair i downloaded. also i dont know how to access the advanced options and as well the f4 or windows key+ b doesnt seem to work
von
Antwort hinzufügen
Erick Hernandez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 687
