Zum Hauptinhalt wechseln
Model A1138 / 1440x960 screen resolution
85 Fragen Alle anzeigen
Immediate shut down independent of battery charge
Hello
My PB shuts down immediately most of the times when the battery is empty or even when it is fully charged. Sometimes I lose my work and the Date and Time, but not always.
The last time the battery has been fully charged and is indicating that it is.
Best regards
Klaus-Dieter
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
3 Kommentare
Does this happen when your computer is plugged in to power too?
von
This morning I selected Sleeping in the menu and the PB shuts down immediately, even the hard drive had no time to position. After Reboot I have lost all my settings, Date, Time and Keyboard Layout.
I have to tell since I used Monolingual I have several problems with software and I do not know if this could be a problem of the removing of Intel code.
Best regards
Klaus-Dieter
von
No, it only happens when the power plug is not connected.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The loss of date and time are coming from a dead PRAM battery that stores this information. Replace it first and then see if your other problems persist, here's the part: [verlinktes Produkt fehlt oder ist deaktiviert: IF154-094]
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Thank you very much. I have already ordered it, but it will take time to be delivered.
I will tell you if it works and will set a score if it fixes the problem.
Best regards
Klaus-Dieter
von
Antwort hinzufügen
MacWiniac wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 581
